User Fields Settings
The User fields tab allows adding arbitrary values to alarm events.
User fields tab
User fields tab
Available options on the User fields tab
Option
Description
Name
Specifies this Field's name
Type
Specifies this Field's type. Available options are 0: String, 1: Integer, 2: Double, or 3: DateTime
Size
Specifies this Field's size
Source
Specifies this Alarm's data source
Propagate?
Forces an immediate update on all alarms that inherit this User Field's value, whenever it receives a forced value or if its Link changes
Add User Field Add User Field
Adds a User Field at the end of this list
Remove User Field Remove User Field
Removes the last User Field on this list
User Fields can only be included or excluded at the end of this list. Excluding User Fields from this list reflects on all Alarm Areas and Sources related to this Alarm Server, but only if the removed Fields were not configured with a forced value or a Link. Otherwise, these Fields still appear on Alarm Areas and Sources. The next figure shows an Analog Alarm with User Fields inherited from an Alarm Server.
Inherited User Fields
NOTE
For more information about the behavior of a User Field from Alarm Areas and Sources, in E3 Studio and at run time, please check the Link, Value, and ValueSource properties on E3 Reference and Scripts Manual.
