Chart Report
Chart Report
Let's create a chart report that copies configurations from Screen's chart. This report must be printed and exported to PDF format.
1.Insert a Report in the project, named "ChartReport".
2.In its Page Header Section, insert an E3Chart object.
3.Open the Scripts Editor by clicking Scripts Editor Scripts Editor.
4.In the Object field, select the PageHeader item and, in the Events field, select the OnBeforePrint item.
5.Between texts "Sub OnBeforePrint" and "End Sub", type the next script.
Set Chart = Report.Sections("PageHeader").Controls("E3Chart1")
Set ScreenChart = Application.GetFrame("Central_Area").Screen.Item("E3Chart1")
Chart.CopyConfig(ScreenChart)
Chart.LoadData()
Script Editor
Script Editor
