Links
Links
Links (or Connections) are associations performed among properties and objects or among properties. Links make creating animations and other types of common logic easier, minimizing the usage of scripts.
By using the Links tab on the Properties Window, users have access to all available object properties and to all possible link types for these properties.
Links tab
Links tab
Users can link an object or create an expression. When creating an expression or linking an object or property to the Source field, this text appears in blue, in case this object corresponds to an existent or loaded item in E3 Studio. If this item does not exist, or if it does not belong to an existing module in the Domain, this text appears in red, and this item is shown as an error, until it is corrected or excluded with the Domain Verifier option.
