Database |
1.If not available yet, insert a new Database in E3Training project, named as "Database".
Add a Database
2.Right-click this Database object, select the Properties option and, on the Configuration tab, select the 0 - stAccess item in the Database field.
3.Configure all connection parameters.
Connection parameters
4.Test the connection with this database.
