Digital |
1.To organize Tags, select the Driver and insert a folder named "Digital".
Add New Folder option
2.The first Digital Tag is a status information (open or closed) of Pump 1. Create an I/O Tag named "Status_P1" on Digital folder.
3.Configure its N parameters according to the following information:
•N1: 1 (PLC address)
•N2: 8 (Operation code, or Coil)
•N3: 0 (Additional parameter)
•N4: 1 (Register address)
4.Right-click the Driver object and select the Activate Communication item to test these settings, or click Activate or Deactivate Communication . In case these settings are correct, this Tag's row must be displayed in blue.
5.Add, on Digital folder, the following Tags:
•Address 2: Status_P2
•Address 3: Status_P3
•Address 4: Status_P4
•Address 5: Status_P5
•Address 6: Status_P6
6.After creating these Tags, test Driver's communication.
Activate communication
