KeyDown
KeyDown
KeyDown(KeyCode, Shift)
Occurs when a key is pressed, regardless of Screen's focus. The parameters on this event are described on the next table.
Available parameters on the KeyDown event
Name
Description
KeyCode
An integer number identifying the ASCII character of the pressed key
Shift
Shows the shortcut key used together with the pressed key:
4: SHIFT key
8: CTRL key
12: CTRL + SHIFT keys
Example:
Sub InitialScreen_KeyDown(KeyCode, Shift)
  'Displays a message box when
  'a user presses a key
  MsgBox "Key code: " & KeyCode
NOTE
For a list with all available key codes for the KeyCode parameter, please check the article Keys Enumeration in Microsoft Developer Network.
