CustomConfig Event |
The CustomConfig event is a feature available starting with E3 version 3.2. It allows creating configuration wizards for instances of ElipseX objects in E3 Studio.
A configuration option appears on the contextual menu of instances of ElipseX objects whenever there is a script linked to the CustomConfig event of the definition of the ElipseX object. When this option is selected on the menu, that event is triggered.
The text that appears on the menu option can be informed in the CustomConfigText property of the definition of the ElipseX object. If this property is empty, a "Configure" text appears, as shown on the next figure.
Configuring an XControl
NOTE |
The script linked to the CustomConfig event executes in E3 Studio, where objects are not active. Therefore, its behavior is different from the usual. |
