Other Implementations |
•Created the IsObjectActive property, which indicates whether a native E3 object is active or not.
•Added to log an information of when E3, client or server, is using a non-standard TCP/IP port, that is, other than 6515 on connections.
•Logs of RECRaw session were redesigned.
•E3 Studio grids now display a tool tip for cell values with hidden or partially hidden text.
•Added in the Full log the registry keys FullLogComCalls, to enable recording all DCOM calls received, and FullLogRecCalls, to enable recording all REC calls sent and received.
