Documentation
Documentation
Added information on E3 documentation about using reserved characters in names of objects.
Removed a note alerting that users had to change a Digital Link's data type so that the exercise about libraries on E3 Tutorial Advanced worked.
Fixed several texts of E3 documentation to replace the expression licensing for product key where it applies. In addition, were added notes on E3 User's Manual explaining how licenses work for Tags and Block Tags.
Updated E3 User's Manual with information about Stored Procedures used by a Storage on a database.
Updated the description of the EnableTextColor property of an Axis on E3Chart's Collection of Axes on E3 Reference and Scripts Manual to indicate that, when disabled, it uses the color defined in E3Chart's ForeColor property.
Updated the topic about including E3Playback in the Demonstration application on E3 User's Manual.
Added a new topic on chapter E3 Studio of E3 User's Manual called Shortcut Keys with shortcut keys used by several commands in E3 Studio.
Updated the topic with usage examples of SQL Server on E3 User's Manual to remove the reference to version 2000, already discontinued.
Added the corresponding properties on E3 Reference and Scripts Manual of the Calculate statistical data, Show average line, and Show minimum and maximum options of the Statistics tab of an E3Chart Pen described on E3 User's Manual.
Added the property corresponding to the Invert scale property on the Axis tab of E3Chart's configuration on E3 User's Manual.
Updated E3 documentation to remove Windows XP, Windows Vista, and Windows Server 2003 from the list of operating systems supported by E3.
Updated all figures on E3 documentation to show the new controls of Common Controls 6.0 library and Windows 10 theme.
