E3Chart |
•Fixed E3Chart's FitPen method to accept the name of a Pen and also a numeric index. This bug occurred since v1.20.126.
•Fixed a problem on the options of the Legend tab of the Properties Window, which were not displayed enabled when this window was opened from within a Report. This bug occurred since v1.19.193.
•Fixed the default values of the BackColor, TextColor, and HeaderTextColor properties of a Legend. This bug occurred since v1.20.55.
•Fixed the behavior of the ForeColor parameter of the ResetConfig method and also its usage on main Axes. This bug occurred since v1.20.275.
•Changed the layout of the Legend tab on Properties Window and created a new window with two tabs for additional configurations. This bug occurred since v4.8.123.
•Added an option to configure Legend's ShowBackground property using the Properties Window. This bug occurred since v1.20.55.
•Removed the option to configure a color on the configuration window of the source of a Legend. This bug occurred since v4.8.231.
•Fixed a problem with Legend's ShowBackground property, which was not saved in E3 Studio. This bug occurred since v1.20.55.
•The edition field of a Legend's Source on the More settings window is now read-only. This bug occurred since v4.8.231.
•Fixed the effect of the ResetConfig method on the visual reference options of Axes. This bug occurred since v4.8.19.
•Fixed the effect of the ResetConfig method on the sources of Scales. This bug occurred since v1.19.191.
•Now the ResetConfig method configures the ShowBorder property to its default value, which is True. This bug occurred since v4.8.12.
•Fixed a problem that prevented configuring negative values for reference lines on the Visual Reference tab of a Properties Window. This bug occurred since v4.8.19.
•Fixed the keyboard focus on the tabs of a Properties Window, which could not return to the tab when clicking an option on that tab. This bug occurred since v1.20.280.
