Documentation
Documentation
Removed information about compatibility with E3Chart on Query's AddField and RemoveField methods and removed a text indicating that Query's DataSource, Fields, GroupBy, Having, OrderBy, Table, and Where properties were read-only but could be changed at run time on E3 Reference and Scripts Manual. This bug occurred since v1.20.1.
Fixed the description of Screen's FillStyle property, which is also common to Screen objects on E3 Reference and Scripts Manual. This bug occurred since v4.7.115.
Updated the descriptions of BackupDiscardInterval, BackupDiscardTimeUnit, DiscardInterval, DiscardTimeUnit, EnableBackupTable, EnableDiscard, VerificationInterval, and VerificationUnit properties, which are common to Alarm Server, Historic, and Storage objects, so that they indicate to which object they refer on E3 Reference and Scripts Manual. This bug occurred since v3.0.365.
Updated the exercise about expressions on chapter Links of E3 Tutorial Developer. This bug occurred since v4.5.250.
Fixed the figure of Properties List that appears on chapter Starting the Application of E3 Tutorial Developer. This bug occurred since v4.7.292.
Fixed a situation where some topics that should not be included on E3 documentation in CHM were improperly added. This bug occurred since v4.5.99.
Reintroduced a paragraph about context variables that was removed from E3 User's Manual on topic Links. This bug occurred since v4.0.205.
Fixed the name of the property defining the line style of a Pen, PenLineStyle, on E3 User's Manual and on E3 Reference and Scripts Manual. This bug occurred since v3.5.98.
Removed the indication that the Size property cannot be changed after activating communication in I/O Block, OPC Block, and OPC UA Block objects on E3 Reference and Scripts Manual. This bug occurred since v1.20.237.
Added the value of the ClassName parameter for OPC UA Driver object in E3StudioApplication's CreateFile method on E3 Reference and Scripts Manual. This bug occurred since v4.5.204.
Fixed standard values of GradientStyle (Screen), BorderStyle (Scale), MatchEntry (List), GridLinesType (E3Browser), LineStyle (Report's Picture), and Alignment (Report's Text) properties on E3 Reference and Scripts Manual.
Fixed the example script for the GradientStyle property of Screen object Scale on E3 Reference and Scripts Manual. This bug occurred since v3.2.140.
