ProductString
ProductString
Text This property returns a String containing the product's name and the installed version of E3 Viewer, such as "E3 5.6.74". This is a read-only property.
Notice that an E3 Viewer can access an object in a Server and retrieve the ProductString property of that Server, according to the next example.
Set server = Application.GetObject("DataServer").Application
MsgBox "Server Version: " & server.ProductString
In the previous example, considering that the DataServer object is in a Server, the text displayed on the dialog box is "Server Version: E3 5.6.74" or "Server Version: E3 (64-bits) 5.6.74".
