UaNodeId |
Specifies the path to perform a browsing of an OPC UA Tag on an OPC UA server. This path is used in OPC UA Driver's RefreshUaNodeIds method to retrieve an OPC UA Node Identifier of an OPC UA Tag, when needed. This property must be filled in to establish communication with an OPC UA server.
