KeepFormatWhenEditing |
Allows an object's value to be edited with or without format. The available options are the following:
•0 - kfNever: Value is always edited without format (default)
•1 - kfAutomatic: Allows a value to be edited in the formatted value, if E3 detects that the formatted text can be interpreted as a value
If a format is considered as incompatible, object's value is edited without format.
