IsSetPoint |
This property is used to determine whether an object behaves as a SetPoint, that is, if it allows editing its Value property. The Value property is a Variant, which may assume any and every type of value. This property is a Boolean and assumes the following behavior: if it is equal to True, it allows edition and, if it is False, it does not allow edition. This behavior can be viewed when E3 Viewer is executing. Default value is False.
