OnError |
OnError(Number, Description, SCode, Source, HelpFile, HelpContext, CancelDisplay)
Triggered by a Report's internal error. If this event is not handled, E3 then displays a generic error message.
Parameters of an OnError event
Name |
Description |
Number |
Integer identifying this error |
Description |
String with this error's description |
SCode |
Integer with OLE subsystem's error code (not used) |
Source |
String with the object that generated this error |
HelpFile |
String with the name and path of a help file |
HelpContext |
Integer of help topic's context referring to this error |
CancelDisplay |
Boolean indicating whether this error must be displayed on a message box |
