Define an Interval Between Process Statistics |
This section allows configuring time options for recording process statistics. Available options in this section are described on the next table.
Interval between process statistics option
Options for interval between process statistics
Module |
Description |
E3Admin |
Configures an interval between E3 Admin's process statistics. Default value of this option is 60 |
E3DBEngine |
Configures an interval between E3DBEngine's process statistics. Default value of this option is 60 |
E3OpcClient |
Configures an interval between E3OpcClient's process statistics. Default value of this option is 60 |
E3PowerEngine |
Configures an interval between E3PowerEngine's process statistics. Default value of this option is 60 |
E3Run |
Configures an interval between E3Run's process statistics. Default value of this option is 60 |
E3Server |
Configures an interval between E3 Server's process statistics. Default value of this option is 60 |
E3UaClient |
Configures an interval between E3UaClient's process statistics. Default value of this option is 60 |
IOServer |
Configures an interval between IOServer's process statistics. Default value of this option is 300 |
Studio |
Configures an interval between Studio's process statistics. Default value of this option is 60 |
Viewer |
Configures an interval between Viewer's process statistics. Default value of this option is 60 |
NOTE |
For all modules, a value of 0 (zero) disables statistical recording. Using a value between one and nine forces E3 to use a value of 10. All values are in seconds. |
