Define a Time for Locked Functions Warnings
Users can define a time, in milliseconds, that a function must be executing so that a warning is generated (EcoLogWarning), informing that this function is probably locked. The configuration item is Time for locked functions warnings (milliseconds).
A value of 0 (zero) in this edition field disables this option. If it is not zero, the minimum acceptable value is 20000. When this item is not modified, it assumes a default value of 30000 milliseconds.
Time for locked functions warnings (milliseconds) option
