Define a Threshold Time for Full Logging Function
Users can define the minimum time to log a function on Full logs. Functions that last less than this time are not logged. The configuration item is Threshold time for logging function (milliseconds).
When this item is not modified, it assumes the default value of 100 milliseconds. Modify this item and fill in the edition field to attribute a different time value. A value of 0 (zero) forces logging all calls. A very low value may sensitively degrade application's performance.
Threshold time for logging function (milliseconds) option
