Define a Watchdog Time-out |
IOServer contains a watchdog mechanism, which monitors calls performed by E3Run. If any of these calls last longer than one minute, the default value, then the following actions are taken:
•An error message is recorded on E3's log
•IOServer process is immediately terminated, causing a DCOM call from E3Run (or from E3 Studio) to fail, probably creating a new process for IOServer
A value of 0 (zero) in the 'Watchdog' timeout (seconds) field disables this watchdog mechanism. Possible values for this option are in the range between 10 (ten seconds) and 3600 (one hour).
'Watchdog' timeout (seconds) option
