Define an E3Run's Wait Time-out
Users can specify the maximum time, in milliseconds, to quit E3Run, by using the E3Run's wait time-out (milliseconds) item.
If this item is not modified, the system automatically assumes a value of 60000 milliseconds, or one minute.
If this item is modified, the configured value indicates the maximum time, in milliseconds, to stop E3Run. If a value equal to 0 (zero) is informed, then E3Run is immediately stopped.
E3Run's waiting time-out (milliseconds) options
