Disable Multiple CPUs
In case of biprocessed computers, users can configure an E3 Server to use only the first or all available CPUs on the computer, by using the Multiple CPUs configuration item.
If this item is not modified, the system automatically assumes that E3 Server executes on all CPUs.
If this item is modified, and the answer to question Enable multiple CPUs? is Yes, E3 Server is enabled to execute on all available CPUs on the computer. A No answer enables E3 Server to execute on a single CPU.
Multiple CPUs option
