Hide a Progress Indicator
Users can select whether to show or hide E3Run's progress window, by using the Hiding of progress indicator window item.
If this item is not modified, the system automatically assumes that this window must be displayed.
If this item is modified, and the answer to question Hide E3Run's progress window? is Yes, this progress window is hidden. If the answer is No, this window is displayed.
Hiding of progress indicator window option
