Enable a Filter |
E3Run implements a COM call filter designed to avoid reentrant calls. This filter by default is disabled and to enable it (recommended only in systems that present errors or locks without an apparent cause), users can modify the Filter enabling item.
If this item is modified, an Yes answer to question Enable COM messages' filter? enables this filter and a No answer disables this filter.
This configuration is read from Registry only when E3Run is started. Therefore, when changing Registry E3 must be restarted.
On E3's Full log users can check for reentrant COM calls, for debugging purposes.
Filter enabling option
