Round Rectangle |
Allows drawing rectangles with rounded corners, created from two vertexes. To use this object, follow these procedures:
1.Select the Round Rectangle option on the toolbar of a Screen.
2.Click the Screen to create the rectangle's origin vertex then drag the mouse diagonally to its final vertex, until the object reaches the desired size and position.
3.On the object's upper left corner, there is a dot responsible for the rectangle's rounding factor. Drag it to its center or to its edge to determine the curve of its vertexes.
