Filters Tab |
The Filters tab allows managing filters from an Alarm Filter.
Filters tab
Available options on the Filters tab
Option |
Description |
Filters |
Combo box with currently available Filters |
Configure |
Opens a configuration window for the selected Filter, described next |
Add |
Adds a new Filter to the Collection of Filters. This option corresponds to the Add method of the Collection of Filters |
Remove |
Removes the selected Filter. This option corresponds to the Remove method of the Collection of Filters. NOTE: The Filter created automatically with an object cannot be removed |
When clicking Configure, the window on the next figure is opened to configure the selected Filter.
Properties of the selected Filter
Available options on the properties window of a Filter
Option |
Description |
Name |
Name of this Filter. This option corresponds to the FilterName property of a Filter object from the Collection of Filters |
Filter by Alarm Area |
Determines a filter by Alarm Area. If users want to use a filter, specify it in this option or leave it blank. This option is equivalent to the AreaFilter property of a Filter object from the Collection of Filters |
Simple Area Filter |
If the Filter by Alarm Area option is not blank, this option is enabled and, if selected, filtering by Area is based only on matching the initial part of a name. Otherwise, it considers the entire name of an Area. This option is equivalent to the SimpleAreaFilter property of a Filter object from the Collection of Filters |
Use custom filter |
Allows informing a custom filter for alarms. This option corresponds to the CustomFilter property of a Filter object from the Collection of Filters |
Filter by type |
Enables the type of filter applied to an alarm. Available options are Only alarms, Only events, or Alarms and events. This option is equivalent to the FilterType property of a Filter object from the Collection of Filters |
Filter by severity |
Enables or disables viewing severity degrees. Available options are Critical, High, Medium, or Low. This option is equivalent, respectively, to the ShowCriticalPriority, ShowHighPriority, ShowMediumPriority, and ShowLowPriority properties of a Filter object from the Collection of Filters |
