Properties
Properties
Every object contains Properties that store information about its features. For example, a Rectangle-type object contains a Name property, which contains its name, and a Width and Height properties, for its width and height respectively, among others. To modify these properties, proceed as described on topic Methods, but select the Properties folder in AppBrowser.
