Initial Screen or Frame of the Application
To test a Frame configuration, let's configure it to be displayed when starting an application.
1.Right-click the View - Viewer and Frames - Viewer item in Organizer to open its Properties Window.
Viewer properties
Viewer properties
2.Select the Frame1 item in the Initial Screen or Frame field.
Initial Screen or Frame option
