Load Data
Load Data
1.To load data from this Formula, insert a button on the SynopticScreen with its Caption property set to "Load" and, on its Click event, create a script with Viewer's LoadFormulaDlg method.
Application.LoadFormulaDlg "ColorFormula"
NOTE
To return the name of a Unit and the selected Values, use the UnitName and ValueName parameters of the LoadFormulaDlg method.
