Analog
Analog
1.Insert a new folder named "Analog".
2.On Analog folder, create the following Tags:
Address 1: Temperature_T1
Address 2: Temperature_T2
Address 3: Level_T1
Address 4: Level_T2
3.Configure their N parameters according to the following information:
N1: 1 (PLC address)
N2: 1 (Operation code, or Register)
N3: 0 (Additional parameter)
N4: 1 to 4 (Register address)
4.Right-click this Driver and select the Activate Communication item to test these settings or click Activate or Deactivate Communication Activate or Deactivate Communication. In case these settings are correct, this Tag's row must be displayed in blue.
