I/O Driver
I/O Driver
An I/O Driver is an E3 module that enables communication with a certain device, by using DLL Drivers supplied by Elipse Software. A manual is supplied along with every Driver and it contains important information regarding configuration of its [P] parameters and other properties. The available types of Driver objects for communication are described on the following table.
Available objects on I/O Drivers
Object
Description
Folder Folder
Defines groups and sub-directories for organizing variables. It does not have a direct relationship with field devices
I/O Tag I/O Tag
Used to define communication with a variable (a memory address) of an acquisition device
I/O Block I/O Block
Used to define communication with several variables (several memory addresses in a sequence) of an acquisition device
Block Element Block Element
Represent each one of the addresses of a Block and are used as if they were I/O Tags. Block Elements can point to each index inside a Block (corresponding to each monitored variable)
