Report |
1.Insert a Report in the project, called "AlarmReport".
2.Right-click the Report's Query1 object and select the Configure option.
3.Select a Database and then the Alarms table.
4.Select the E3TimeStamp field and any other field wanted.
5.For each field selected in the Query, insert a SetPoint on the Detail Section and configure its DataField property.
6.Finish this Report's design as wanted.
