Reports
Reports
A Report is an ActiveX component called ActiveReport, which allows viewing and printing instantaneous values from system variables and data stored on databases (Alarms, Historic objects, Queries, and Formulas). To use a Report, right-click Organizer's View - Reports item, in Domain mode, select the Insert Report in option, and then select a project's name.
A Report also uses a Query object. This object allows users to specify a database source for data viewed on the Report.
A Report contains several Sections. Each Section of a Report contains a group of controls that are processed and printed at the same time, as a unit.
