Server Objects
Server Objects
To access an object executing in a Server from a Screen Object or an ElipseX, users must use the Application.GetObject method. Example:
Server objects
Server objects
Application.GetObject("Data.InternalTag1"): Internal Tag on the Data Server
Application.GetObject("Database"): Database
