MouseDown
MouseDown
MouseDown(Button, ShiftState, MouseX, MouseY)
Occurs when any mouse button is pressed on a Screen. Use the MouseDown event to determine specific actions when a user clicks a Screen. The parameters of this event are described on the next table.
Available parameters on the MouseDown event
Name
Description
Button
Shows the mouse button pressed:
1: The mouse button pressed is the left one
2: The mouse button pressed is the right one
4: The mouse button pressed is the middle one
ShiftState
Shows the key pressed along with the mouse button:
4: SHIFT key
8: CTRL key
12: CTRL + SHIFT keys
MouseX
Shows the X coordinate where the mouse button was clicked on a Screen
MouseY
Shows the Y coordinate where the mouse button was clicked on a Screen
Example:
Sub InitialScreen_MouseDown(Button, ShiftState, MouseX, MouseY)
  'Shows a message box with
  'the mouse pointer coordinates
  MsgBox "X Coordinate: " & MouseX & _
    vbNewLine & "Y Coordinate: " & MouseY
