XF_Tank
XF_Tank
1.Insert a new XFolder in the library and name it as "XF_Tank".
2.Change its FriendlyName and InstanceName properties to "Tank" and "TK", respectively.
3.Let's insert a figure to be displayed in the instances of this object. To do so, insert in the IconPath property the name of the Tank object inserted as a Resource in the application.
XFolder properties
XFolder properties
