REC Configuration
REC Configuration
Define a Compression Level
Users can enable compression of communication packets using the REC protocol between E3 Server, E3 Viewer, and E3 Studio.
Define a Connection Time-out
For situations when an E3 Server is starting and protection device's detection is slow, users can control the maximum time E3 Studio or E3 Admin take to connect to an E3 Server.
