User Fields |
Users can specify database configurations and determine fields to generate an alarm table, and each field contains a corresponding property. If users want to insert more information on this table, on the User fields tab they can add arbitrary values to alarm events.
User fields tab
Available options on the User fields tab
Option |
Description |
Name |
Determines the field's name |
Type |
Determines the field's data type (String, Integer, Double, or DateTime) |
Size |
Determines the field's size |
Source |
Determines an Alarm's data source |
Propagate |
Forces an immediate update of all alarms inheriting the value of this User Field, whenever it receives a forced value or if its Link changes |
