GetADORecordSet
GetADORecordSet
The Query's GetADORecordSet method returns a Recordset of type ADO (ActiveX Data Object), resulting from the execution of a configured Query.
The ADORecordset object is used to access records from a database table and contain the properties and methods described on the next tables.
Properties of an ADORecordset object
Name
Description
BOF
Returns True if pointer's position is before the first record
EOF
Returns True if pointer's position is after the last record
RecordCount
Returns the number of records on a table
Methods of an ADORecordset object
Name
Description
MoveFirst
Moves the pointer to the first record
MoveLast
Moves the pointer to the last record
MoveNext
Moves the pointer to the next record
MovePrevious
Moves the pointer to the previous record
To access records individually, use the Fields("FieldName"). command. Example:
Set RS = Screen.Item("Query1").GetADORecordset()
For i = 1 To RS.RecordCount
  Field1 = RS.Fields("Field1").Value
  Field2 = RS.Fields("Field2").Value
  Field3 = RS.Fields("Field3").Value
  MsgBox Field1 & vbTab & Field2 & vbTab & Field3
Next
