Studio |
•Focus on child objects of E3 Studio (Organizer, Gallery, Properties List, and Object Counting) and on Views (Scripts Editor, and Screen's Design tab) is kept when using the ALT + TAB shortcut key to toggle focus among applications, with the possibility of moving through E3 Studio windows using the F6 key. Organizer always receives focus when E3 Studio starts, if visible, whether it is docked or floating. When one of the child windows is opened, by using the corresponding option on the View menu, that one always receives the focus. In addition, focus is kept when closing windows and Views.
•The title of the warning window for copying and pasting Links was changed to "Existing Links". The question on this window was simplified, as well as the titles of buttons, by using an existing template for windows. This bug occurs since v2.5.89.
•Changed the behavior of Save and Save All commands in E3 Studio to always remain available and not change focus during edition. This bug occurs since v2.0.99.
•Fixed the loading of ElipseX definitions occurring in E3 Studio when saving any ElipseX on the same library. This bug occurs since v4.6.104.
•Fixed the edition of VARIANT values in Picks and Digital Links to auto-detect the data type of the typed value, instead of rejecting values incompatible with the current data type. This bug occurs since v1.19.87.
•Fixed a problem on the file protection window, which did not allow operations via keyboard after adding or removing a protection. This bug occurs since v3.2.49.
•Fixed a failure on Application Wizards and on Script Documentation Wizards using the ALT + C shortcut key to finish the Wizard execution. This bug occurs since v1.21.42.
•Adjusted the sizes of Properties Windows for when DPI (Dots Per Inch) is different from 96. This bug occurs since v1.20.15.
•Fixed the internal border on Picks and on the Configuration tab of Database's Properties Window to not cut the text if DPI (Dots Per Inch) is greater than 100%. This bug occurs since v1.19.89.
•Fixed the drawing of internal buttons of edition boxes, which could be misplaced with a DPI (Dots Per Inch) greater than 96 (100%). This bug occurs since v4.7.145.
•Fixed an unexpected quit in E3 Studio when registering libraries with definitions that use other definitions.
•Users now cannot trigger some shortcut keys when pressing more keys than needed. This bug occurs since v4.7.119.
•Fixed the behavior of the CTRL + A shortcut key to occur on the focused window and not on the last opened View but without focus. This bug occurs since v3.1.79.
•Implemented a switch on tabs of the Properties Window by using the keyboard and fixed the keyboard focus when opening that window on a tab that is not the first one.
•Fixed the switch among tabs of a View using shortcut keys CTRL + PAGE UP or PAGE DOWN, which locked on the Scripts tab.
•Implemented a handling of E3 Studio shortcut keys on any tab of the Properties Window. This bug occurs since v0.1.29.
•Fixed how shortcut keys work on edition boxes. This bug occurs since v3.2.209.
•Fixed the behavior of the Rename option of the contextual menu of the Design tab of objects, which had no effect. This bug occurs since v1.20.371.
•Fixed how the CTRL + A shortcut key worked on edition boxes of controls of type Tree Controls. This bug occurs since v2.0.117.
•The Cut and Copy options of E3 Studio's toolbar now are enabled only when these options are allowed. This bug occurs since v1.22.25.
•Users cannot open a duplicated Find and Replace window anymore. This bug occurs since v4.5.36.
•Fixed how the ALT + F4 shortcut key works when a Screen or XControl Definition is selected. This bug occurs since v3.0.36.
•Contextual menus of projects are now equivalent in Organizer and in Explorer. This bug occurs since v3.0.239.
•The mini-dialog to edit Links on the Links tab of the Properties Window now accepts global shortcut keys. This bug occurs since v1.0.16.
•Fixed the behavior when editing the name of an object on the Properties Window and on the Properties List. This bug occurs since v3.5.81.
•Focus on the object clicked on Organizer is performed correctly when the object with previous focus is not on Organizer's visible area, whether in floating or sliding mode. This bug occurs since v1.20.301.
•Removed inappropriate options from the contextual menu. This bug occurs since v3.0.242.
•Removed the Save command, which was duplicated in projects. This bug occurs since v3.0.231.
•Fixed a GPF when editing Links with multiple selection. This bug occurs since v1.21.98.
•Items are not copied duplicated anymore when in multiple selection. The Copy option of contextual menus now correctly appears when in multiple selection. This bug occurs since v1.19.45.
•Now users cannot select a Query anymore when in edition mode of a Screen. This bug occurs since v3.0.220.
•Fixed the focus on the selected object with a single or double mouse click in Organizer when focus comes from another application. This bug occurs since v5.0.191.
