Other Implementations
Names of enums in several properties (TextAlignment, VertTextAlignment, FillStyle, GradientStyle, BackgroundStyle, and BorderStyle) of Screen objects where converted to uppercase.
HeapLog statistics now display in details the number of allocated and free blocks per size.
Optimized the loading and activation of folders with hierarchies of XFolders and XObjects.
Studio and E3Run processes now have a special scheme to allocate memory, which leads to a considerable increase in performance (above 40%) in operations demanding allocation or release of large amounts of memory, such as when loading or unloading an application.
Scripts of ElipseX instances are now shared, speeding up the activation time of objects and decreasing memory usage.
Performed a small optimization in memory usage of E3 objects (an improvement of approximately 2%).
Improved the performance of creating Links in applications with many Links (more than 50000).
Slightly reduced the memory usage of E3 objects in general, also improving the loading or starting time of applications.
