Interface |
•Vertically aligned the text relative to non-availability of Windows XP style on the options of Customize window of E3 Studio.
•Standardized fonts for E3 windows to Tahoma. This bug occurs since v3.0.79.
•Added a period to the phrase referring to the configuration of restrictions by Absolute Limit on Formula's restriction configuration. This bug occurs since v1.18.147.
•The horizontal line of the Classes of objects window of advanced export options for objects now follows this window's width. This bug occurs since v3.2.46.
•Fixed the margin for controls on Frame tab of properties of Frameset objects. This bug occurs since v0.1.33.
•Fixed a problem on Tag Browser window, in which the text box could be misaligned when resizing it. This bug occurs since v4.0.60.
•Fixed problems with truncated texts on E3.
•Fixed the size of fonts on Yes, No, Yes (All), and No (All) windows of E3. This bug occurs since v4.5.61.
•Fixed the size of texts in E3 Studio's opening windows when using a DPI (Dots Per Inch) above 96. This bug occurs since v2.5.126.
•Fixed several translation problems on E3.
•Fixed in E3 Tweak the translation of texts of type "Module 'XXX'" to "'XXX' Module". This bug occurs since v4.6.77.
•Fixed the enabling of controls on Configuration tab of the Alarm Server in E3 Studio, where options could appear enabled in cases where these options have no effect. This bug occurs since v1.20.235.
