Reports
Reports
Fixed the behavior of Reports loaded in the server, when it was not possible to access server objects via Links. This bug occurs since v3.0.238.
Fixed a memory leak whenever a Report was loaded in a E3 Viewer. This bug occurs since v4.0.128.
Fixed a lock that may occur in the server if an error in a script occurred when generating a Report. This bug occurs since v1.18.114.
