Documentation
Documentation
Fixed the usage example of the InsertColumn method of a Pen's Legend in E3 Reference and Scripts Manual. This bug occurs since v3.2.140.
Added the description of Source property of a Multisource Link Row in E3 Reference and Scripts Manual. This bug occurs since v3.2.175.
Added descriptions for OnRead events of OPC Block, OPC Block Element, and OPC Tag objects in E3 Reference and Scripts Manual. This bug occurs since v1.18.147.
Added information about the Storage Session object in E3 Reference and Scripts Manual, related to the AddField, AddValue, and Commit methods. This bug occurs since v2.5.128.
Created separated topics to enlist events, methods, and properties of Link collections (the Links property) and Discrete Alarm Source Subconditions (the Subconditions property) in E3 Reference and Scripts Manual. This bug occurs since v4.0.155.
Created in E3 Reference and Scripts Manual a new topic in common properties of Server Objects, which contains common properties of Server Objects behaving as Alarm Areas. This bug occurs since v4.0.169.
Updated the description of the Write method of the I/O Driver object in E3 Reference and Scripts Manual to remove a mention to an ever-synchronous data writing.This bug occurs since v3.0.57.
Added a new topic about Multiple Links in chapter Links of E3 Tutorial for Developers. This bug occurs since v3.5.164.
Performed corrections in several texts and exercises of the E3 Tutorial for Developers. This bug occurs since v3.5.164.
Fixed the description of the Saves and Runs the Domain button of E3 Studio in E3 User's Manual and E3 Tutorial Developer. This bug occurs since v3.5.163.
Updated E3 Tutorial Developer on the chapters where there are images with the configuration window for Analog Alarms. This bug occurs since v4.0.187.
Removed references to specific versions of E3 in documents where this information is not needed.
Fixed the screen resolution of CHM files to comply with project configuration. Now all files are opened with the resolution of 1024 by 768 pixels. This bug occurs since v3.5.183.
Fixed the example of the topic Reports - Usage Examples - Capturing a Screen and Generating a Print Preview, in E3 User's Manual. This bug occurs since v1.19.87.
Fixed the item ActorID on topic Alarms - Alarm Server - Configurations for Alarm Table Generation in E3 User's Manual. This bug occurs since v1.19.383.
