Properties
Properties
Usage example of E3Chart properties in a Report
The following scripts must be created in a Report's Page Header Section, using the OnBeforePrint event. Examples:
Sub OnBeforePrint
  'Using an E3Chart in a Report
  Set chart = _
    Report.Sections("PageHeader").Controls("E3Chart1")
  chart.LoadData()
  chart.FitAll
Sub OnBeforePrint
  ' This script copies configurations from
  ' E3Chart chartfrom object to E3Chart chart
  ' which is used in the report.
  Set chartfrom = _
    Application.GetFrame().Screen.Item("E3Chart1")
  Set chart = _
    Report.Sections("PageHeader").Controls("E3Chart2")
  chart.CopyConfig(chartfrom)
  chart.LoadData()
  chart.FitAll
NOTE
Descriptions for E3Chart properties in a Report are the same explained on topic View - E3Chart - Properties.
