Properties
Properties
This section contains information about the properties of a Report's Layout (ActiveReport) object.
NOTE
All properties described here are part of the ActiveReport (AR) object, which is encapsulated in a Report object. These properties are only valid inside AR's scope and cannot be accessed from outside this object.
The available properties on this section are the following:
_PageBottomMargin
_PageLeftMargin
_PageRightMargin
_PageTopMargin
AllowSplitters
documentName
MaxPages
ParentReport
PrintWidth
RulerVisible
ScriptDebuggerEnabled
ScriptLanguage
ShowParameterUI
Status
TOCEnabled
TOCVisible
ToolbarVisible
UserData
Version
WaterMark
WaterMarkAlignment
WaterMarkPrintOnPages
WaterMarkSizeMode
