Accessing ElipseX Objects from the ElipseX Itself
When creating an ElipseX, users can declare properties (XProperties) and insert objects, which can be Screen objects (XControl) or server objects (XFolder and XObject). To access XProperties via scripts, access the property's name directly.
Design tab
Design tab
Properties tab
Properties tab
For example, in the previous figure there is an object XControl1 with a Property1 property, and objects Text1 and Rectangle1.
The Property1 property, which is a Boolean-type, can be accessed using the next script.
Sub XControl1_OnStartRunning()
  XControl1.Property1 = True
Or else using the next script.
  Property1 = True
If an ElipseX contains internal objects, then users can use the Item method to get a reference for these objects, as in the next script.
  Item("Text1").Value = "engine"
  Item("Rectangle1").ForegroundColor = RGB(212, 208, 20)
