Events
Events
Events are occurrences related to an object that allow triggering scheduled actions. There are basically two types of events, Physical or External and Internal. Physical Events are, for example, user actions. In case users type on the keyboard, the relevant information can be the pressed key, or if users point and click the mouse, the relevant information can be the cursor position and buttons' status. Internal Events are, for example, value changes in a variable or Tag in an application. Since a Tag can be linked to an external device, users can say that internal events can have physical associations, such as temperature changes in a chamber, for example. The available events on this section are the following:
OnStartRunning
OnStopRunning
