Working with Collections
A Collection is an object that manages a set of similar objects. The objects contained in a collection are referred by indexes, similarly to array references. Users can add or remove individual objects from a collection, as in the next example.
Sub CommandButton1_Click()
  ' Add a Pen to an E3Chart1 object
  Screen.Item("E3Chart1").Pens.AddPen "Pen"
Sub CommandButton2_Click()
  ' Removes the first Pen
  Screen.Item("E3Chart1").Pens.Remove 0
NOTE
The first object in a collection has an index of 1 (one).
All collections have a common property named Count, which is the number of existing objects or children, according to the next example.
  ' Shows a dialog box with the number of Pens
  MsgBox Screen.Item("E3Chart1").Pens.Count
