WindowStayOnTop
WindowStayOnTop
Boolean Indicates whether E3 Viewer's window must always be on top of other windows. Default value of this property is False. This is a read-write property, but changing its value at run time does not change settings for an already opened E3 Viewer, only for windows opened using E3 Viewer's settings.
